@Avi Thank you for your response, indeed this method worked.
But I also realized that there is a tool to actually move the axes, it is not very precise as you are not able to type the value of the rotation angle but you can adjust it afterwords with the protractor.
I preferred to work with this second method for not having a 4th axis that could make me confused. I hope that OpenStudio takes this change into consideration, if it does not, please let me know, I would be glad.
