I follow the same procedure - this implies 2 models for the Best Practice building. However, in GN25 the asterix sign * does not apply for glazing (G value and light transmission). What do you do in this case, keep the actual G and LT, or use the values from GN25?
I consider that by using the GN25 values i do not respect the "credit spirit" and i obtain more credit than usual.
