Inspection of the source code shows that the use side outlet temperature at the end of the previous system time step is used to control indirect (source side) heating demand for plant loop heat sources serving a WaterHeater:Stratified tank.
For air-source heat pump water heaters, there are fields to specify the height of the control sensor(s).
