From the Input/Output Reference documentation for the Shading:Overhang
object in EnergyPlus, there are no inputs for material information -- only where this should should be placed above a window or door. Since this is a shading object, and there are no inputs for setting transmittance either, it will likely assume that the shade only blocks direct sunlight and doesn't reflect or transmit direct sunlight.
Depth is an input field for the Shading:Overhang
object, so you should be able to set that to your desired values using JEplus.
