Re-install OpenStudio, and make sure you select the option to install the SketchUp plugin. Further details on installing if that doesn't work: https://unmethours.com/question/27973/sketchup-2018-compatability/
The toolbars load separately sometimes, and you need to drag them into the upper slot to fix them in the interface. You might have accidentally closed out of that toolbar when you launched SketchUp 2018 the first time, or it's there, just hidden at the base of your screen behind the main window. Try re-installing SketchUp and checking that the OpenStudio toolbars are visible under View -> Toolbars -> OpenStudio Tools. Use Plugins -> OpenStudio -> File => Open OpenStudio Model if that isn't working.
Also, you can't open .skp sketchup files in OpenStudio. The plugin saves an .osm model and you work off of that in the OpenStudio App.
