A design alternative in pat is as follows:
Seed model + configured measure(s) => new model => IDF => Results
So no, it will not override anything in the Seed model (that wouldn't be a good idea...) but you'll find all the resulting OSMs corresponding to your design alternatives in your PAT folder after you run them, so you can always select the one that worked best for you for ulterior work.
So no, it will not override anything in the Seed model (that wouldn't be a good idea...) but you'll find all the resulting OSMs corresponding to your design alternatives in your PAT folder after you run them, so you can always select the one that worked best for you for ulterior work.you.
