HVACTemplate only understands other HVACTemplate objects, so it is not aware of the other HVAC objects that were added for the electric radiant heat.
To add additional HVAC components, start with an input file that has only the HVACTemplate objects (no other HVAC objects) and run the simulation. Then take the expanded idf output file (expidf), rename that to newname.idf and edit this file to add the ZoneHVAC:LowTemperatureRadiant:Electric object and add it to the zone equipment list that is already there from the templates.
