TEST REPORT: OPERATING SYSTEM = MS WINDOWS7 32 Bit Running updated osm models (converted from 1.4.0 to 1.6.0) with OpenStudio 1.6.0 produced the following results: (1) OpenStudio produced an out.idf file, while in the process of the "json" user file script a stderr file was produced with the following messages: DL is deprecated, please use Fiddle QSslSocket: cannot resolve TLSv1_1_client_method QSslSocket: cannot resolve TLSv1_2_client_method QSslSocket: cannot resolve TLSv1_1_server_method QSslSocket: cannot resolve TLSv1_2_server_method QSslSocket: cannot resolve SSL_select_next_proto QSslSocket: cannot resolve SSL_CTX_set_next_proto_select_cb QSslSocket: cannot resolve SSL_get0_next_proto_negotiated
(2) when I tried to start EP simulations with the out.idf file via EP-Launcher, a) the OpenStudio Version of EP 8.2.0 crashed (regularly) b) the stand-alone version of EP 8.2.0 successfully completed the simulations
(3) after de-installing the separate stand-alone version of EP8.2.0, OpenStudio still was unable to run EnergyPlus (!).
 During de-installation(s) of EnergyPlus versions, there is the option of not removing several DLLs,
 because they might still be needed by other programs: I chose not to have these DLLs removed.
(4) Testing execution of the same osm models with the Linux version of OpenStudio 1.6.0 produced better results: these simulations were completed successfully.
(5) NEXT TESTS:
 de-install OpenStudio 1.6.0;
 re-install OpenStudio 1.6.0;
 trying to run simulations from osm models fails the same way as described in (1)
 re-install extra EP 8.2.0 on separate drive.
 Now I can at least run simulations again by procedure  (2b)
CONCLUSION: On my Windows7 system (32bit), the bundled EnergyPlus 8.2.0 is useless, and in order to perform simulations I need an extra EP 8.2.0 installation. BUT PROBLEM IS SOLVED BY JOREGONS ANSWER.
TEST REPORT: OPERATING SYSTEM = MS WINDOWS7 32 Bit REPORT: Running updated osm models (converted from 1.4.0 to 1.6.0) with OpenStudio 1.6.0 produced the following results: (1) OpenStudio produced an out.idf file, while in the process of the "json" user file script a stderr file was produced with the following messages: DL is deprecated, please use Fiddle QSslSocket: cannot resolve TLSv1_1_client_method QSslSocket: cannot resolve TLSv1_2_client_method QSslSocket: cannot resolve TLSv1_1_server_method QSslSocket: cannot resolve TLSv1_2_server_method QSslSocket: cannot resolve SSL_select_next_proto QSslSocket: cannot resolve SSL_CTX_set_next_proto_select_cb QSslSocket: cannot resolve SSL_get0_next_proto_negotiated
(5) NEXT TESTS:
CONCLUSION: On my Windows7 system (32bit), system, the bundled EnergyPlus 8.2.0 is useless, and in order to perform simulations I need an extra EP 8.2.0 installation. BUT PROBLEM IS SOLVED BY JOREGONS ANSWER.installation.
TEST REPORT: Running updated osm models (converted from 1.4.0 to 1.6.0) with OpenStudio 1.6.0 produced the following results: (1) OpenStudio produced an out.idf file, while in the process of the "json" user file script a stderr file was produced with the following messages: DL is deprecated, please use Fiddle QSslSocket: cannot resolve TLSv1_1_client_method QSslSocket: cannot resolve TLSv1_2_client_method QSslSocket: cannot resolve TLSv1_1_server_method QSslSocket: cannot resolve TLSv1_2_server_method QSslSocket: cannot resolve SSL_select_next_proto QSslSocket: cannot resolve SSL_CTX_set_next_proto_select_cb QSslSocket: cannot resolve SSL_get0_next_proto_negotiated
(5) NEXT TESTS:
CONCLUSION: On my Windows7 system, the bundled de-installing the seperate EnergyPlus 8.2.0 is useless, and in order to perform simulations I need an extra EP 8.2.0 installation.
(Windows 7) does not help ! The deeper causes remain unclear.
