Visual inspection of the components shows correct implementation. However, if you search for the coil name it only appears once. One component uses a 1 (one) in the name (ACDXCoil 1) and the other uses the lowercase letter L. So it's not the coil type that is the problem, it's a misspelled coil name.
 AirLoopHVAC:UnitarySystem,
   MiniSplitUnit,           !- Name
   Coil:Cooling:DX:SingleSpeed,  !- Cooling Coil Object Type
   ACDXCoil 1,              !- Cooling Coil Name
   ACDXCoil l,       !- Name
Visual inspection of the components shows correct implementation. However, if you search for the coil name it only appears once. One component uses a 1 (one) in the name (ACDXCoil 1) and the other uses the lowercase letter L. So it's not the coil type that is the problem, it's it a misspelled coil name.
   ACDXCoil l,       !- Name
