But, you need to be IN a space to add an illuminance map. The section cut is useful for being able to see the interior of your model, but you still need to dbl-click the space you want to work in before you can add a map. You'll see the space displayed clearly with all other spaces sorta greyed out when you are "in the zone" so to speak.
