Not a solution but just a observation: there is something wrong with the figure 2. As an integrated value, energy consumption either rise or stay flat. It should never drop.
Also, the ZoneHVAC:LowTemperatureRadiant:VariableFlow object is not controlled by thermostat object. It has its own thermostat. And the Heating Control Temperature Schedule Name should be the set thermostat temperature of the zone.
Also, the ZoneHVAC:LowTemperatureRadiant:VariableFlow ZoneHVAC:LowTemperatureRadiant:VariableFlow object is not controlled by thermostat object. It has its own thermostat. And the Heating Control Temperature Schedule Name should be the set thermostat temperature of the zone.
Also, the ZoneHVAC:LowTemperatureRadiant:VariableFlow object is not controlled by thermostat object. It has its own thermostat. And the Heating Control Temperature Schedule Name should be the set thermostat temperature of the zone.ZoneHVAC:LowTemperatureRadiant:VariableFlow
