The error is informative:
You must run the ExpandObjects program for "HVACTemplate:Zone:IdealLoadsAirSystem"
In Eppy, you must pass the expandobjects=True to the run() function (eg: idf1.run(expandobjects=True)). By default this parameter is False.
See the docstring of the run function eppy.runner.run_functions:
def run(...)
expandobjects : bool, optional
Run ExpandObjects prior to simulation (default: False)
In Eppy, you must pass the expandobjects=True to the run() function (eg: function. By default this parameter is False.idf1.run(expandobjects=True)).
def run(...)
