I applied all your comments on the file, and still have the same issue in the schedules. I uploaded the files that I used earlier based on your comment and also the output.csv file. I am observing one - hour forward shift in the output schedule that I am exporting. Also, if I realign the data manually, still there are intervals that those input and output schedules are not the same.
https://drive.google.com/drive/folders/1-VpUrgRIfJJsw9C2-PVDSFTtHyL-gfty?usp=sharing
In the 1minSchedule file which I am trying to reach that. From beginning the 0.0001 values that I have in that file are only because not to use zero value there. The only data that I have is from Jun-Aug.
