Thanks for the bug report. It appears to be specific to having a heat pump water heater in a multifamily building with, e.g., a basement. The fix is pretty trivial. Please download the updated file, rename to energyplus.py, and save it to your C:\Program Files (x86)\NREL\BEopt_2.8.0\Modeling\ directory (overriding the file that is there). Then re-run the simulations.
