E+ completed successfully according to the screenshots of your eplusout.err you uploaded to google drive, so I'm pretty sure this is an error in the reporting stuff, likely from something divided by zero or infinity, or perhaps you have non-sanitized names for one of your measure option names or design alternative names.
It seems that you're using OpenStudio 1.14.0, and I definitely recall hitting and reporting such problems in the past with PAT as highlighted by the issue I link to below (they have been fixed since them).
Here's what you can try:
- Apply the Reduce Lighting Loads by Percentage but do NOT apply the OpenStudio Results Measure, see if that works (see issue#2670)
- Ensure you don't use any special characters including any of
in either the measure option name nor the design alternative names. (See issue#2673) - Worst case, try with the latest OpenStudio 2.5.1
For the record, I downloaded your model, an ran it with the Reduce Lighting Loads by Percentage and the OpenStudio Results measure inside the OpenStudio Application (not PAT) version 2.5.1 and it worked. I'd have tried with PAT, but it's still not available on Linux...
Edit:
Try removing all special characters from your OSM model. Namely one material and one window material:
- C1 Concrete Precast Panel 10" => C1 Concrete Precast Panel 10in
- Double pane with ½” air space R=2.04 => Double pane with 0.5in air space R=2.04,
There is definitely something wrong with the user's model itself, meaning something that doesn't please PAT (it's a PAT bug! I've filed an issue on OpenStudio-PAT here), the run fails due to ASCII to UTF8 conversion. I think the ½
is really the guilty one.
Here's what the datapoint's run.log shows at the end:
[15:44:29.401331 DEBUG] Passing measure OpenStudioResults of type ModelMeasure
[15:44:29.401359 INFO] Finished applying OpenStudio measures.
[15:44:29.401369 DEBUG] Communicating measure output attributes to the output adapter
[15:44:33.570363 ERROR] Found error in state 'os_measures' with message ["\"\\xE2\" from ASCII-8BIT to UTF-8:/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:81:in `write'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:81:in `<<'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:81:in `block in save_osm'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:81:in `open'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:81:in `save_osm'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/jobs/run_os_measures.rb:60:in `perform'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/run.rb:261:in `step'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/run.rb:210:in `run'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:176:in `block in perform'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:170:in `open'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/server/app/workers/run_simulate_data_point.rb:170:in `perform'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/performable_method.rb:26:in `perform'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/backend/base.rb:81:in `block in invoke_job'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `block in initialize'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `execute'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:40:in `run_callbacks'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/backend/base.rb:78:in `invoke_job'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:230:in `block (2 levels) in run'\n/usr/share/rvm/rubies/ruby-2.2.4/lib/ruby/2.2.0/timeout.rb:88:in `block in timeout'\n/usr/share/rvm/rubies/ruby-2.2.4/lib/ruby/2.2.0/timeout.rb:98:in `call'\n/usr/share/rvm/rubies/ruby-2.2.4/lib/ruby/2.2.0/timeout.rb:98:in `timeout'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:230:in `block in run'\n/usr/share/rvm/rubies/ruby-2.2.4/lib/ruby/2.2.0/benchmark.rb:303:in `realtime'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:229:in `run'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:312:in `block in reserve_and_run_one_job'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `block in initialize'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `execute'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:40:in `run_callbacks'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:312:in `reserve_and_run_one_job'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:213:in `block in work_off'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:212:in `times'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:212:in `work_off'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:175:in `block (4 levels) in start'\n/usr/share/rvm/rubies/ruby-2.2.4/lib/ruby/2.2.0/benchmark.rb:303:in `realtime'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:174:in `block (3 levels) in start'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `block in initialize'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `execute'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:40:in `run_callbacks'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:173:in `block (2 levels) in start'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:172:in `loop'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:172:in `block in start'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/plugins/clear_locks.rb:7:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/plugins/clear_locks.rb:7:in `block (2 levels) in <class:ClearLocks>'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:79:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:79:in `block (2 levels) in add'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:61:in `block in initialize'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:79:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:79:in `block in add'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:66:in `execute'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/lifecycle.rb:40:in `run_callbacks'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/worker.rb:171:in `start'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/command.rb:137:in `run'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/command.rb:125:in `block in run_process'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/application.rb:270:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/application.rb:270:in `block in start_proc'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/application.rb:279:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/application.rb:279:in `start_proc'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/application.rb:300:in `start'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/controller.rb:59:in `run'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons.rb:197:in `block in run_proc'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/cmdline.rb:92:in `call'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/cmdline.rb:92:in `catch_exceptions'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons.rb:196:in `run_proc'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/command.rb:123:in `run_process'\n/home/julien/Software/Others/OpenStudio-PAT/depend/OpenStudio-server/gems/gems/delayed_job-4.1.5/lib/delayed/command.rb:98:in `daemonize'\nbin/delayed_job:6:in `<main>'"]}
Edit:
Try removing all special characters from your OSM model. model. Namely one material and one window material:
There is definitely something wrong with the user's model itself, meaning something that doesn't please PAT (it's a PAT bug! I've filed an issue on OpenStudio-PAT here), the run fails due to ASCII to UTF8 conversion. I think the conversion½
Edit:
There
Edit 2: there
is definitely something wrong with the user's model itself, meaning something that doesn't please PAT (it's a PATHere's what the datapoint's run.log shows at the end:
Edit:
Edit 2: there is definitely something wrong with the user's model itself, meaning something that doesn't please PAT (it's a PAT bug!), the run fails due to ASCII to UTF8 conversion, though I didn't pinpoint what causes it.
Edit: Try removing all special characters from your OSM model. Namely one material and one window material:
