You have to open .idf file with idf editor, and replace "CONSTUCTION" by "CONSTRUCTION" with a R, in the class "ComponentCost:LineItem" >> "Line item Type" >> for each construction type (each object in the edf editor).
It's working properly on my model.
Unfortunately I don't see where to fix the bug in the .osm file.
For my point of view, its not related to a "non unique name" but in the idf lines generation process introduced in the OS v2.5.
