You can also place an AirTerminal:XXX on the first branch, then click the demand splitter, and assign thermal zones from there. For each new thermalZone, the (last) AirTerminal will be cloned
Place the Air Terminal you want, (here an AirTerminal:SingleDuct:Uncontrolled), click on the demand splitter. You get the right pane showing the thermal zones you want to assign.
Before clicking
Check the boxes for the thermal zones you want to assign, see result:
After selecting zones
