If you refer to the EnergyPlus I/O Reference for this section, you will find this
If the method “NominalCapacity” is selected then the fields “Design Water Flow Rate”, “U-Factor Times Area Value at Design Air Flow Rate” and “U-Factor Times Area Value at Free Convection Air Flow Rate” must be left blank, but the fields “Nominal Capacity” and “Free Convection Capacity” must be entered as described below.
You will need to calculate the 'Free convection capacity' as detailed here link text
You will need to calculate the 'Free Free convection capacity' capacity as detailed here
link text
