Some results might be helpful, e.g. a series of plots of the rtrace data from the different distances. A quick glance of those trans
parameters seems to indicate that you have a totally diffuse transmitter; your description of your results and your setup are somewhat confusing to me though. Recommend you make a couple of renderings of a space with a clear glass
mat and your trans
mat and compare the visual results, in addition to evaluating the point calcs.
