Are you comparing the total VRF cooling load against the VAV AHU cooling load? If you run the system sizing report that just gives you the size of the DOAS cooling coil, not the VRF cooling load.
On the discrepancy on the VAV preheat coil, it could be coming from your leaving temperature set point. You might want to compare the coil leaving temperature to the set point for the DOAS.
