Thank you for the great explanation. I used the same method to create a free cooling coil coupled with water cooled DX system for an office building in Phoenix AZ. the problem is the Free cooling coil does not show any cooling effect on the passing air while the water temperature after the coil is increase and there is some cooling rate. should there be any set point temperature after the FCC? any suggestion?
