As you correctly stated, if you are using eppy to generate the csv files you have to do.
idf.run(readvars=True)
Unfortunately idf.run(readvars=True) fails on some of the earlier versions of Energyplus. Test have shown that it will work on EnergyPlus-8-9-0
- This bug has been documented in two issues
- https://github.com/NREL/EnergyPlus/issues/5058
- https://github.com/NREL/EnergyPlus/issues/5898
Briefly:
- to generate the csv files Energyplus has to run
ReadVarsESOafter the simulations are complete. - older versions of EnergyPlus have the
ReadVarsESOlocated in an unexpected place. - So it cannot run
ReadVarsESOand will not generate the csv files ReadVarsESOis located in the right place inEnergyPlus-8-9-0and the csv files will be generated here.- Many of the earlier versions of Energyplus will also run
ReadVarsESOsuccessfully and will generate the csv files. But this varies on different platforms. If you are able to test and give me a list, I'll add it to the eppy documentation.
