Generating the HTML file
To generate an html input file, your IDF file has to have the objects that will generate the HTML file. Add these two objects to your IDF file, and it will generate the HTML file.
Output:Table:SummaryReports,
AllSummary; !- Report 1 Name
OutputControl:Table:Style,
HTML, !- Column Separator
None; !- Unit Conversion
Reading Energyplus outputs thru eppy or python.
- Eppy has functions to read the HTML file. It is documented here
- EnergyPlus will also generate csv files
- python has an excellent package called
csv, that you can call byimport csv. Googlepython csvto learn more. - Pandas http://pandas.pydata.org is a much more high powered package you can use to read csv files.
- To visualize the data use https://matplotlib.org/ or https://d3js.org/
if you are using eppy to generate the csv files you have to do
idf.run(readvars=True)
Note: some of the earlier version of EnergyPlus will not run with readvars=True. It will run on EnergyPlus-8-9-0
