Make sure you have set the program to Do System Sizing Calculation as shown in the image above. This setting should be on if you are autosizing VRF. You should also turn on the Zone Sizing & Plant Sizing if you are autosizing everything.
The file is using version 1.4.0, if anyone has that on their computers - I am not able to open this file using version 1.6.0
Make sure you have set the program to Do System Sizing Calculation as shown in the image above. This setting should be on if you are autosizing VRF. You should also turn on the Zone Sizing & Plant Sizing if you are autosizing everything.VRF.
Make sure you have set the program to Do System Sizing Calculation as shown in the image above. below. This setting should be on if you are autosizing VRF.
