After many hours of debugging E+ code it turns out DView is the problem not E+. E+ generates the correct data but DView plots the maximum altitude at 10am instead of midday. A huge 2 hour offset. Extract of E+ CSV file below - the maximum is clearly at 12:00:
07/19 11:00:00,59.72341312759839
07/19 12:00:00,67.54636375727424
07/19 13:00:00,67.32938849937168
So why does DView plot it at 10AM? Annoying. Unfortunately to graph this data in Excel takes considerable extra manipulation because the timestamp in the first column is not valid (no year).
Is there any Windows program similar to DView that works better? Eg open CSV direct into the program & have a graph displayed without lots of extra setting up?
07/19 10:00:00,48.04278892426238 07/19 11:00:00,59.72341312759839
07/19 13:00:00,67.32938849937168 07/19 14:00:00,59.23275071902709 07/19 15:00:00,47.449338102294898
So why does DView plot it at 10AM? Annoying. Unfortunately to graph this data in Excel takes considerable extra manipulation because the timestamp in the first column is not valid (no year).Annoying.
