Yes; the input/output documentation is out of date.
This section in the engineering reference describes the calculation procedure for AirflowNetwork with a Fan:VariableVolume and AirTerminal:SingleDuct:VAV:Reheat terminals.
You can also run the example file and verify variable airflow through the air system using the System Node Mass Flow Rate output variable as well as AirflowNetwork operation with the AFN Linkage Node 1 to Node 2 Volume Flow Rate variable.
Yes; the The input/output documentation is out of date.
This section in the engineering reference describes the calculation procedure for AirflowNetwork Airflow Network with a Fan:VariableVolume and AirTerminal:SingleDuct:VAV:Reheat terminals.
You can also run the example file and verify variable airflow through the air system using the System Node Mass Flow Rate output variable as well as AirflowNetwork Airflow Network operation with the AFN Linkage Node 1 to Node 2 Volume Flow Rate variable.
