Had to redraw from floor plan level and connected all rectangles that were not touching other surfaces. And then used plugin surface match. I still have some wrong boundary conditions that need to be set manually. OSM measure of surface matching and intersect surfaces failed to help in my model as they took more than 30 minutes with no progress and so I canceled.
Suggestions for the first-timers: - At the floor plan level, all zones or rooms should be touching other surfaces for at least two sides to avoid this error at the later time. -Surface Match does not always do what you expect, so check the boundary conditions and diagnose the colors if they represent the correct situation. Change manually using Inspector from the plugin.
And hope you can fix all errors.
