Yes, EnergyPlus can handle Cold Rooms, Walk-Ins, and Freezers. See the Refrigeration section in the Input Output Reference. There are also example files for refrigeration included with EnergyPlus.
You can specify the product load with the Restocking Schedule field in the Refrigeration:WalkIn
object. You'll need to calculate the load yourself; it doesn't autocalculate.
