You don't have to run the rakefile task until you are planning to do development on the measures (i.e., make changes to them). You can just download/clone the measures and run them as is.
That said, the warning about those 2 measures is safe to ignore. Currently these 2 measures (to model PV and interact with the FloorspaceJS tool) are not available, hence the warnings. (The PV measure should be available in a month or so, we're just waiting on the PVWatts model to be available in an OpenStudio release.)
You don't have to run the rakefile task until you are planning to do development on the measures (i.e., make changes to them). You can just download/clone the measures and run use them as is.
