If you want the full results from the Radiance measure, you'd need to download and unzip the individual datapoints; from there you could browse the measure's output directory as you would if you'd run the measure with the app, and look at illuminance map data or the datapoints' daylight metrics report csv files. The Radiance measure only reports out the building-level daylight metrics to PAT's results interface.
There is no Radiance results report measure at this time.
