For modeling Radiant Slab Cooling refer to the following link:
http://www.beepindia.org/sites/default/files/L8%20-%20Demonstration%20of%20modelling%20of%20Radiant%20cooling%20system%20in%20Design%20Builder.pdf
I hope Radiant panel can be also modeled using the same methodology.
Regarding Refrigeration you need to tweak process load as desribed in DB help:
http://www.designbuilder.co.uk/helpv5.3/#_Process_gains.htm?Highlight=refrigeration
Do let me know if you are able to model the same.
http://www.beepindia.org/sites/default/files/L8%20-%20Demonstration%20of%20modelling%20of%20Radiant%20cooling%20system%20in%20Design%20Builder.pdfhttp://www.beepindia.org/sites/default/files/L3%20-%20Basics%20of%20radiant%20cooling%20system-Panel%20cooling.pdf
