You can add an OpenStudio measure named AddOutputVariable which can be found in the BCL and enter the variable name as Zone Mean Air Temperature and select the desired reporting frequency. After the simulation, the output can be viewed in the DView where you can compare the Site Outdoor Air Drybulb Temperature and Zone Mean Air Temperature
