On the run tab, If the status of a datapoint is "completed Fail" but you value in the red box for errors is "0" and you don't see an error under any measures, then click on "EnergyPlus Results" in the workflow. It will expand to show EnergyPlus warnings and errors. It is likely that your simulation had a fatal error as shown on the example below. Currently warnings and errors directly from EnergyPlus don't roll up to the totals in PAT, only measure warnings and errors show up. Because the simulation failed the reporting measures didn't run. That is why you are seeing a warnings about "OpenStudio Results measure was not included".
