As I see it you can delete the Setpoint Manager and run it as is. After all you use constant flow rate fans. I have checked it on your model it will not through any Errors just few Warnings stating that you don't have any control for that loop (which is the case) and that you can't do sizing without thermostat setting (again you hard sized the fans so no sizing needed to my best understanding).
