I did some experimentation and found that once I split the IDF file into two halves (in a text editor) I was able to save each half separately in the IDF Editor without issue. This is a workable solution for me at this time.
When I recombine the two halves that were saved by IDF Editor, the error occurs again.
@JasonGlazer identified that the problem was due to IDF editor running out of memory since there were a huge number of schedule:compact objects in the file. Solution was to edit the .IDD file to reduce the number of fields allocated to each one of these, to a number that will be enough fields to accommodate each of the schedule:compact objects you will have (i.e. define it with enough fields for the longest schedule:compact object you think you will ever need), but not so many that IDFEditor runs out of memory. Refer to comments below from Jason for further info.
@JasonGlazer identified that the problem was due to IDF editor running out of memory since there were a huge number of schedule:compact objects in the file. Solution was to edit the .IDD file to reduce the number of fields allocated to each one of these, to a number that will be enough fields to accommodate each of for all the schedule:compact objects you will have (i.e. define it with enough fields for the longest schedule:compact object you think you will ever need), want to have, but not so many that IDFEditor runs out of memory. Refer to comments below from Jason for further info.
When I recombine the two halves that were saved by IDF Editor, the error occurs again.again. The issue may be related to file length, or some limit on number of objects?
@JasonGlazer identified that the problem was due to IDF editor running out of memory since there were a huge number of schedule:compact objects in the file. Solution was to edit the .IDD file to reduce the number of fields allocated to each one of these, to a number that will be enough for all the schedule:compact objects you want to have, but not so many that IDFEditor runs out of memory. Refer to comments below from Jason for further info.
When I recombine the two halves that were as saved by IDF Editor, the error occurs again. The issue may be related to file length, or some limit on number of objects?
