I see slowdowns when I have lots of output variables, and ask DView to convert them to IP (presumably because of all the converting being done), but never up to 15+ minutes.
What operating system are you using? Does the time to open depend on which output variables you report?
You might want to log an issue here, including operating system used, OpenStudio version, etc.
Otherwise, you can get ResultsViewer from previous OS installations (described here).
Otherwise, you can get ResultsViewer from previous OS installations (described here).), or use the version @Jason DeGraw carved out.
Otherwise, you can get ResultsViewer from previous OS installations (described here), or use the version @Jason DeGraw carved out.
