The term you are looking at is the room temperature (as denoted by the 'r'). The subscript 'k' is the time step.
Edit: looking at this a bit more thoroughly I think the subscript 'k' is actually the target temperature for the space, although that isn't stated within the image you have linked it would make more sense.
The term you are looking at is the room temperature (as denoted by the 'r'). temperature. The subscript 'k' is the time step.
