Follow David's answer to add output meter and output variables to your simulation.
If you have utility rates entered, energy costs will appear in the " Tariff Report" and "Economics Results Summary Report" in the EnergyPlus results.
To export time series data, in the OpenStudio GUI under the "Results Summary" tab, click the "Open DView for Detailed Reports" button. Select your time series, and then right click to export.
