This is a unique request as sensible only heating cannot remove moisture from a zone. It could control RH by heating the space to result in lower RH (i.e., zone condition state point moves right on a psyc chart), but that would be very uncomfortable. The typical method would be to activate a cooling coil and remove moisture from the zone, and reheat if necessary.
