I checked the code and it appears to use the water inlet node temperature in the calculations. Did you specify water cooled in the input? If there is still a problem send your input file to me or the help desk at support@energyplus.helpserve.com.
AirConditioner:VariableRefrigerantFlow,
  WaterCooled,               !- Condenser Type
I checked the code and it appears to use the water inlet node temperature in the calculations. Did you specify water cooled in the input? If there is still a problem send your input file to me or of the help desk at support@energyplus.helpserve.com.
