mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.
In my original post I mentioned that honeybee would struggle with large models. That is no longer the case. Honeybee version 063 no longer has this issue.
mapasqual @mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.
@mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.names.
Best,
Fabian
Best,
Fabian
