Gotcha!
Rraustad, thanks a lot for your answer!
Just to verify, am I inputing the data correctly in each field? Should I really use the labels I mentioned: Other, Temperature, Biquadratic, SI?
eg. For Performance Data is Chilled Water Supply Temperature correctly imputted as Independent Variable 1? eg2. Still for Performance Data is Entering Condenser Air Temperature correctly imputted as Independent Variable 2?
And for all other input data I mentioned, did I correctly correlated the data I have to the variable in the sheet?
Best Regards
