There might be another way to go around this matter. You could use the Efficiency Schedule
of PhotovoltaicPerformance:Simple
to simulate changing efficiency opposite to the loss which occurs due to the fact that the PV surface is fixed. You could do that using EMS.
There might Might be another way to go around this matter. You could use the Efficiency Schedule
