You can also download all releases from the GitHub repo:
https://github.com/NREL/OpenStudio/releases
The same is true for EnergyPlus.
Be mindful of the tags next to them, you probably want to avoid "Pre-release" for production work unless you know what you're doing, and use "Latest Release" in most cases.
