As the warning stated this is a problem of the weather file encoding. For some reason the file you are using have different encoding than the one you can find in EnergyPlus site here. I advise you to download again the weather files and make sure not to open and resave them. Also make sure you relanch Euclid after you tried loading the damaged weather file. so you start fresh.
