First, I would double-check that your zone's thermostat is set up correctly. You can refer to this post for details.
If your thermostat is set up correctly, then check your ZoneHVAC:IdealLoadsAirSystem object. Some input fields that could be causing this unmet hours issue are:
- Availability Schedule Name: Check if there are schedule values of 0
- Minimum Cooling Supply Air Temperature: Check if the minimum supply air temperature is too high
- Cooling Limit: Check this and it's related input fields if maximum supply air flow is too low
- Cooling Availability Schedule Name: Check if there are schedule values of 0
