The OpenStudio Results measure needs the EnergyPlus output to be in SI to do its unit conversion to IP.
To not receive that error, don't include the OS Results measure with your run, and just do the EnergyPlus unit conversion measure.
See here, here, and related discussion here.
The OpenStudio Results measure needs the EnergyPlus output to be in SI to do its it's unit conversion to IP.
