If you transition your EnergyPlus example files, then the BCVTB should work with E+ 8.8. However because of some recent changes in EnergyPlus, examples which use the erl external interface variables are not working. Were you able (prior to transitioning the files) to run the EnergyPlus example files which come along with the BCVTB with E+ 8.5?
