The Section 7 tests in ASHRAE Standard 140 are Class II tests used for software specific to residential modeling. TRNSYS was not used to generate any of the example results in the standard. I am unaware of TRNSYS being run for these tests in the past. TRNSYS has been run with all of the Class I tests in the standard.
