I've try to install following Julien's answer but i can't solve package dependencies, so i've decided to install from Sources last OpenStudio 2.4.0 version into Ubuntu 16.04 64 bits operating system ok :), following this steps:
- Download last Source Code .zip or .tar.gz compressed file from https://github.com/NREL/OpenStudio/releases
 - Extract OpenStudio compressed file into your sources directory
 If .zip: unzip file.zip -d dest_folder or if .tar.gz: tar xf file.tar.gz -C dest_folder
sudo apt-get install dpkg-dev git cmake-curses-gui cmake-gui libssl-dev libxt-dev libncurses5-dev libgl1-mesa-dev autoconf libexpat1-dev libpng12-dev libfreetype6-dev libdbus-glib-1-dev libglib2.0-dev libfontconfig1-dev libxi-dev libxrender-dev libgeographiclib-dev chrpath
Install cmake from source:
- wget https://cmake.org/files/v3.7/cmake-3.7.1.tar.gz
 - tar -xzf cmake-3.7.1.tar.gz
 - cd cmake-3.7.1/
 - ./configure
 - make
 - sudo make install
 - (check that your cmake is 3.7.1)
 cmake --version
sudo apt-get install autotools autotools-dev automake
mkdir build
cd build
ccmake ../openstudiocore
press c to configure, and then press g to generate
make GenerateIddFactory
make GenerateIddFactoryRun
(still inside build directory)
- make
 (process run during a long time: hours)
sudo make install
OpenStudio installed from sources ok :)
To Get EnergyPlus version:
- energyplus --version
 openstudio energyplus_version
To Run OpenStudioApp application:
- OpenStudioApp
Hi Siv & team!
I've try to install following Julien's Juliens answer but i can't solve package dependencies, so i've decided to install from Sources last OpenStudio 2.4.0 version into Ubuntu 16.04 64 bits operating system ok :), following this steps:
 - cd cmake-3.7.1/
 - ./configure
 - make
 - sudo make install
 cmake --version
mkdir build
cd build
- make
sudo make install
- OpenStudioApp
Enjoy & Share ;) hugs, @tximikel
